Does a Rec 709 monitor still need color management?
COW Forums : DaVinci Resolve
Linfeng Niu
on Mar 7, 2019 at 6:34:38 pm
HI, I just got a monitor that can be turned into 709 tuned color space with a hardware setting. I am wondering if it is still necessary to manually set the output gammut and colorspace into rec709 in Davinci?
Thanks for your posts and insight.
Glenn Sakatch
Re: Does a Rec 709 monitor still need color management?
on Mar 9, 2019 at 4:24:34 pm
if you are viewing in rec709, then resolve should be set to rec709.
Resolve usually defaults to rec 709 for its color management settings, so you shouldn't have to go in a manually change anything.
I think there is an assumption that you are working in REC709, until you tell it otherwise.
Glenn
