Resolve, 2x GPU's Pro's and Con's
COW Forums : DaVinci Resolve
Kieran Nicholas
on Jan 23, 2019 at 1:19:03 pm
Hey
Ok so I am in the need of some advice. I am currently running one nVidia 1060GTX GPU, which is a 6gb card.. What I am wondering is, is it worth getting a second GPU (as above) to run in the machine. I'm rendering out EXR's for Turnover at 4+k. The speed isn't the issue, its more of running other things while this is working away. I also need to render ARRIMXF's to EXR which I am using the Arri Converter to do, as well as create QT's and run Avid to update cuts (yes sometimes all at the same time)
The system is:-
AMD Ryzen 7 3.6 16 core
64gb Ram
nVidia 1060GTX 6gb
256SSD (Windows)
4tb Media
22tb Raid
After some thoughts as to whether its worth doing or spend the bucks and get a bigger boat?
Regards
K
Live Long and Prosper
Marc Wielage
Re: Resolve, 2x GPU's Pro's and Con's
on Jan 24, 2019 at 1:11:57 am
Resolve is demanding enough that I think you're better off using a second machine if you need to do background tasks while rendering. Use a network connection to copy files across when necessary.
Kieran Nicholas
on Jan 24, 2019 at 10:09:42 am
Hey
Not really an option as this is my own kit.. As I said speed isn't really the issue, its more of the fact I have a lot of other background processes going on.
K
