Ripple Delete keyboard shortcut not working on Windows machine
COW Forums : DaVinci Resolve
Kenneth Maultsby
on Dec 2, 2018 at 12:50:47 am
Just discover this problem while taking a training course. My Ripple Delete shortcut is not working. I did a mark in and a mark out on a section in the timeline and attempted to do a Ripple Delete which the command should be Shift + Backspace. It will work if I go to the Edit drop down and select Ripple Delete. I also checked the Keyboard Customization and it is ok. I also did a test on the Edit drop-down list and did a Ripple cut which is Ctrl Shift X which shortcut did work which is the same thing. At least it worked the same way. Any suggestions?
Glenn Sakatch
Re: Ripple Delete keyboard shortcut not working on Windows machine
on Dec 2, 2018 at 4:17:33 pm
on my box it is just the delete key as opposed to the backspace key which is a non ripple delete.
Glenn
