DR 15.2 ACES and FUSION
COW Forums : DaVinci Resolve
Andi Winter
on Nov 19, 2018 at 11:58:27 am
dear all!
on ACES color managed projects, the sdi output in the color tab or the edit tab is the same. in the fusion tab it seems that the odt to rec709 is not applied.
i do realize there are viewer luts in fusion, but i could not find the appropriate one, that gave me the exact same result as in the other tabs. plus: why do i have to determine this again? in the project settings the idt and the odt are determined already...
anyone doing this already and has some hints or tipps? what do i do wrong?
thanks
andi
Simon Ubsdell
Re: DR 15.2 ACES and FUSION
on Nov 19, 2018 at 2:45:36 pm
[Andi Winter] "in the fusion tab it seems that the odt to rec709 is not applied.
That's exactly as it should be. It be hugely undesirable if that were not the case.
Simon Ubsdell
tokyo productions
hawaiki
Andi Winter
on Nov 19, 2018 at 10:21:19 pm
if so, please tell me why.
Theodore Miesner
on Nov 29, 2018 at 6:53:29 pm
Hey Andi!
What worked for me was using the ACES Transform to monitor in fusion while still using the MediaOut for color.
Hope this helps!
-Theo
