Loudness mixing
COW Forums : DaVinci Resolve
Craig RussillRoy
Loudness mixing
on Oct 17, 2018 at 6:18:17 pm
Hi MooCowers,
Has anyone been able to export a -23LUFS correctly ?
I have loaded in a file I know that is -23LUFS and getting some madness not even close to it readings ... any advice or tricks would be nice
12816_this.png.zip
FCPX 10.3.1
Telestream Vantage 7.0
Telestream Switch 3.1
Adobe CC 2017
1 x 4TB Thunderbolt R4
1 x BMD Express
1 x SmartView
Telestream Vantage 6.3
Check out the free iBook broadcast delivery 101 on itunes
Michael Gissing
Re: Loudness mixing
on Oct 18, 2018 at 1:07:34 am
Firstly the calibration for -23 or -24 is in the preference menu. If you want to run the loudness, you need to reset and run from the beginning. Assuming you have done all that do you have everything at unity levels, no EQ or dynamics and correct patching and panning?
I have no issue dropping a correct LUFs mix file into the timeline and outputting it before QC confirms the exact same levels. I have also confirmed the Fairlight page levels are correct on the same mix files but there are lots of ways clip level or track levels can be changed.
Craig RussillRoy
Re: Loudness mixing
on Oct 18, 2018 at 12:23:38 pm
Thanks Micheal
All very odd, there is differently something wrong somewhere, I put my hands up on operator error - but yes to all your comments on this and still not getting the -23i as intended, will continue to mine for the answer, thank you
FCPX 10.3.1
Adobe CC 2017
1 x BMD Express
1 x SmartView
