davinci not linking footage in slowed down frame rate
COW Forums : DaVinci Resolve
Anastasia Antonova
on Sep 24, 2018 at 8:15:48 am
Hey! So I made a premiere sequence and usually have no trouble going from Premiere XML export to a DaVinci import. I'm guessing because these clips are stretched out they aren't linking to the original footage? I tried to have it link to every folder in my project folder and none of them worked. Does anyone know the issue?
thanks
stas
Tero Ahlfors
Re: davinci not linking footage in slowed down frame rate
on Sep 24, 2018 at 10:38:37 am
Did you change the clips' frame rate in Premiere from the interpret footage dialog?
Anastasia Antonova
on Sep 24, 2018 at 8:06:22 pm
I used change clip speed/duration or time remapping for some of them.
