Release of DaVinci Resolve 15b7
COW Forums : DaVinci Resolve
Peter Chamberlain
on Jul 26, 2018 at 3:23:29 am
DaVinci Resolve 15 Public Beta 7 is available now as a free download from http://bmd.link/CWdTn9.
Thank you to everyone who have used our previous betas and providing feedback as it’s very helpful for our ongoing stability and development. Please continue to report bugs with steps to repo, system information and diagnostic logs on the v15 beta sub forum and if you have a bug, please review the forum for similar issues in the specific beta build you are using before you start a new thread.
This update lets you view custom clip colors in bins as well as clip annotations in the timeline viewer on the Edit page. DaVinci Resolve 15 Studio public beta 7 also improves match frame functionality, adds support for Resolve FX and GPU accelerated OpenFX to the Fusion page, adds support for Saver nodes in Fusion and enables rendering of Dolby Vision and HDR10+ clips with tone mapping. This update also supports higher bit rate and lossless Kakadu JPEG 2000 encoding.
DaVinci Resolve 15.0b7 Key Features:
Added support for caching compound clips, Fusion clips and nested timelines
Added initial support for using ResolveFX plugins in the Fusion page
Added support for GPU accelerated OpenFX plugins on the Fusion page
Added initial support for saver nodes in the Fusion page
Added support for applying LUTs on compound nodes
Added support for converting a shared node to a corrector node
Added support for encoding at higher bit rates for Kakadu JPEG 2000 when rendering DCP and IMF in DaVinci Resolve Studio
Added support for Kakadu based lossless JPEG 2000 encoding in DaVinci Resolve Studio
Added support for custom clip colors for subtitle elements
Added support for showing clip color indicator on Media Pool and Color page clip thumbnails
Added support for rendering with Dolby Vision/HDR10+ tone mapping applied
Added support for exporting Dolby Vision XMLs along with renders
Added support for Alt/Option + middle click to copy Dolby Vision trim metadata for the current target display
Added support for Alt/Option + Shift + middle click to copy Dolby Vision trim metadata for all target displays
Added support for a clip thumbnail indicator to show clips analyzed for Dolby Vision and HDR10+ on the Color page
Added support for tool usage badges in the Color page
Added support for showing clip marker annotations on the timeline viewer
Added support for displaying audio channel names in clip attributes
Added support for search in the Fairlight page track and marker index
Added support for swapping clips in the Edit timeline using Cmd/Ctrl+Shift and dragging
Added support for deleting transitions across clips when one of the clips is deleted
Added support for performing match frame for the selected clip in the timeline
Added support for the 3D Lookup table interpolation option for DCTLs
Added support for keyframing OpenFX dropdown and checkbox based parameters
Added support for a clipping option when converting from a larger gamut and/or gamma in ResolveFX Color Space Transform
Added support for resetting edited audio samples in a clip
Added support for automatically setting alpha mode based on metadata when importing still images
Added support for storing the alpha channel when caching to Uncompressed 16-bit float - HDR
Added support for hardware accelerated decode of Long GOP Panasonic AVC clips on NVIDIA hardware
Added support for importing clip markers from a Final Cut Pro 7 XML file
Added support for preserving bin hierarchy when importing media and metadata from a Final Cut Pro 7 XML file
Improved mouse interactivity when dragging Power Curve Windows on the Color viewer
Improved scripting support with ability to add and query markers, flags and clip color metadata
Improved performance when rendering H.264 clips on Windows
Issues Addressed:
Media:
Addressed an issue where changing a media storage mount would sometimes result in black frames when wiping powergrades
Addressed an issue where replacing still frames in the media pool would not work correctly
Addressed an issue where certain video clips would appear incorrectly rotated in the Media Pool
Addressed an issue where previewing some media pool clips with video field processing enabled would cause a crash
Addressed an issue where control room meters would not reflect all channels when previewing clips in the Media page
Addressed an issue where syncing audio for a clip in the media page viewer would not refresh the viewer
Edit:
Addressed an issue where imported subtitle files would sometimes show incorrect line wrapping behavior
Addressed an issue where imported subtitles would not reflect the correct formatting
Addressed an issue where dragging subtitles between tracks would not refresh the caption list in the inspector
Addressed an issue where adding a subtitle would cause the output sizing and blanking to be ignored
Addressed an issue where playback would sometimes stutter and stop when a Fusion title was loaded in the Edit page inspector
Addressed an issue with render cache when creating a timeline with Fusion titles
Addressed an issue where navigating keyframes for Fusion titles and generators from the inspector would not work on the Edit page
Addressed an issue where editing Fusion clips or titles would sometimes result in media offline frames
Addressed an issue where Fusion titles would sometimes appear black on Windows systems
Addressed an issue where newly added timelines would not honor a custom target loudness value in project settings
Addressed an issue where custom defaults for transition lengths would not be persisted across an application restart
Addressed an issue where custom video track heights would not be persisted across an application restart
Fusion:
Addressed an issue with incorrect Depth Merge results in the Merge node when GPU processing was enabled
Addressed an issue where Fusion titles would sometimes appear shifted when opening a saved project
Addressed an issue where adding multiple Fusion titles in succession would result in incorrect behavior
Addressed an issue where updating the default settings on the Text+ tool would cause issues with subsequent changes to the title
Addressed an issue where tracking would not be correctly applied to a PaintGroup when previewed on the Edit or Color pages
Addressed an issue where new comps would sometimes not be shown in the Fusion page in collaboration mode
Addressed an issue where shapes drawn in the Fusion page would not be displayed on the SDI output
Addressed an issue where dragging a Fusion clip across timelines and undoing the action would cause a crash
Addressed an issue where applying chroma keyer or ultra keyer on scaled images would display a black background
Addressed an issue where sampling the output of a downstream node using keyer tools would cause flickering
Addressed an issue where render cache for clips with Fusion effects would sometimes be invalidated after an application restart
Addressed an issue where passing alpha channels via MediaOut nodes from the Fusion page to the Color page would sometimes cause a crash
Color:
Addressed an issue where split screen previews would not update correctly when switching between albums
Addressed an issue where the render cache would sometimes not be persisted across application restarts
Addressed an issue where the display node graph previews would not update correctly when selecting different timelines in the gallery
Addressed an issue where previewing LUTs or composite modes would invalidate the render cache
Addressed an issue where DCTL OpenFX nodes would behave incorrectly when applied from a still or after an application restart
Addressed an issue where converting a node to a shared node would invalidate the node cache
Addressed an issue where stabilizing a clip with video field processing enabled would cause a crash
Addressed an issue where switching projects in the Color page would sometimes cause a crash
Addressed an issue where locking or unlocking a node would cause the clip to recache
Addressed an issue where using the white balance color picker on the viewer would sometimes cause a crash
Addressed an issue where color tracing between timelines without any matches would sometimes cause a crash
Addressed an issue where some ResolveFX blurs would not be applied correctly on clips with blanking enabled
Addressed an issue where applying ResolveFX Dust Buster on a clip with input sizing would not behave correctly
Addressed an issue where simultaneous displays for HDR and SDR would not work on clips without Dolby Vision analysis
Addressed an issue where adding data burn-in to a project would sometimes make the viewers go blank
Addressed an issue where delivering stereoscopic clips in side by side or top bottom mode would sometimes cause a crash
Addressed an issue where customized printer light hotkeys would sometimes not be saved correctly
Fairlight:
Modified default audio crossfades to 0dB
Addressed an issue where splitting a clip with transitions on the Fairlight timeline would cause inconsistent behavior
Addressed an issue where track names would be incorrectly refreshed on the Fairlight page if a timeline was selected in the media pool
Addressed an issue where FairlightFX would sometimes not process all audio channels in a track
Addressed an issue where Mute automation would sometimes mute only one channel in a stereo track
Addressed an issue where resetting a track EQ would not reset custom frequencies
Addressed an issue where restoring a deleted linked track would not undo correctly
Addressed an issue where synced audio would sometimes not playback correctly
Addressed an issue where recording audio from an audio USB device would sometimes fail when a Blackmagic Design playback device was enabled
Addressed an issue where audio recording would not work correctly for projects created on Windows and imported to macOS
Addressed an issue where edited audio samples would sometimes not be persisted correctly
Addressed an issue where editing audio samples could not be undone
Addressed an issue where changing track color or track name in the Fairlight page could not be undone
Addressed an issue where dragging clips to create a timeline in the Fairlight page would sometimes make the audio meters unresponsive
Addressed an issue where clicking on the media pool would cause recording to be canceled on the Fairlight page
Addressed an issue where undoing the deletion of a multichannel track would not correctly restore patching
Addressed an issue where inserting a track in a timeline with armed tracks would result in incorrectly armed tracks
Addressed an issue where individual speaker gains in speaker setup would not be correctly applied
Addressed an issue where clip pitch changes above 24 semitones would not be applied correctly
General:
Addressed an issue where canceling H.265 renders would sometimes cause an application hang on macOS
Addressed an issue where rendering individual clips on a timeline with Fusion title would cause an application hang
Addressed an issue where power windows with softness would behave incorrectly when rendered at source resolution
Addressed an issue where Power Mastering would not output audio
Addressed an issue where capturing Quicktime clips from tape would not record audio
Addressed an issue where rendering H.264 on Windows on a render job created on macOS would sometimes cause a crash
Addressed an issue where some projects would not be listed in the Project Manager when switching between databases
Addressed an issue where resetting a global shortcut for a single page would reset it for all pages
Addressed an issue where project backups would fail when using some custom backup locations
Addressed an issue where auto-save would not be performed when the application was minimized
Addressed an issue where canceling changes in the Preferences dialog would reset the speaker settings to use system settings
Addressed an issue where importing some FCPXML files created by some third party applications would cause a crash
Addressed an issue where importing a timeline XML exported from Resolve would not relink correctly
Addressed an issue where EDLs and ALEs would be exported with additional new lines on Windows
Addressed an issue where a Final Cut Pro 7 XML exported from DaVinci Resolve would sometimes not have audio
Addressed an issue where ganging timecode to tape would not work
General performance and stability improvements
