Enabling video field processing causes aliasing in downscaled clips
COW Forums : DaVinci Resolve
Joe Bender
on Jul 21, 2018 at 1:12:56 am
Hi all,
Getting ready to conform/color a new project in Resolve, which includes a lot of downscaled 4K footage to a 1080p timeline and a few interlaced archival clips. So in order to correctly deinterlace the archival clips, I turned on video field processing. That works correctly for the interlaced archive, but it also creates serious aliasing in the downsampled 4K clips. This is not just a display artifact, it is present in the rendered footage. Now, I can handle the interlaced archive in a separate project, but for simplicity's sake I'd like to do the whole film in one project if possible. Is this something that you've encountered, and is there a workaround?
I am using:
Resolve 15b6
iMac 5k 4.2gHz 40GB RAM
RX 580 8GB
eGPU RX580 8GB
macOS 10.13.6
Many thanks,
Joe
Massimo Alberto Croce
Re: Enabling video field processing causes aliasing in downscaled clips
on Jul 23, 2018 at 8:12:03 pm
You turned on video field processing on project setting? For progressive output this setting must turned off.
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com
Joe Bender
on Jul 23, 2018 at 8:36:06 pm
Hi Massimo, thanks for your reply.
I enabled video field processing because as far as I could tell that was the only way to get Resolve to deinterlace the archival footage correctly. Is there another method that I should use instead? If there's something else I missed there please enlighten me.
Thanks again,
Joe
on Jul 23, 2018 at 9:20:31 pm
deinterlace is a clip setting, leave video field processing off and tick "enable deinterlace" on clip attributes for interlaced footage ,
this function is only available in Davinci Resolve Studio.
Joe Bender
on Jul 23, 2018 at 9:52:07 pm
Yes, that's the nominal workflow, but when following that Resolve Studio was not deinterlacing my clips, just making them 'wavy', misinterpreting the fields or something. Resolve only correctly deinterlaced the clips when I turned video field processing on. I'll try again to verify, but that's the behavior I was experiencing.
on Jul 24, 2018 at 12:08:33 pm
remember that you are using a beta software, have you tried with DR 14?
