track & blur a face for part of a shot
COW Forums : DaVinci Resolve
Thomas Kaufman
on Jul 12, 2018 at 4:25:16 pm
I'm new to Resolve and would like to blur a face when someone turns towards camera, but keep the rest of the shot un-blurred. I tried to place key frames where I want the blur to begin and end along the timeline but I must be missing something -- the blur stays in place the whole time. How can I accomplish this?
many thanks,
Thomas Kaufman, DP
Washington, DC
Ole Kristiansen
Re: track & blur a face for part of a shot
on Jul 12, 2018 at 7:06:51 pm
Try youtube - davinci resolve track and blur a face !
Marc Wielage
on Jul 13, 2018 at 5:30:07 am
[Thomas Kaufman] "I tried to place key frames where I want the blur to begin and end along the timeline but I must be missing something"
You could use a power window to constrain the blur, then use Opacity to allow the blur or remove it as you see fit. But you do have to keyframe it. It's basically dissolving the effect in when you need it, then dissolving it out when you don't need it.
Thomas Kaufman
on Jul 13, 2018 at 12:21:42 pm
Thanks, Marc, very helpful!
Thomas Kaufman, DP
Washington, DC
Eric Santiago
on Jul 13, 2018 at 1:30:52 pm
[Marc Wielage] "then use Opacity to allow the blur or remove it as you see fit."
Most of the time I just do a next frame transform.
Similar to "now you see it, now you dont".
The opacity keyframe works the same but most of the time I am having to key the position anyway.
This is during those tricky tracking settings.
Too bad Resolve didnt have a Adjustment Layer type of option or simple on/off keyframe toggle.
Marc Wielage
on Jul 13, 2018 at 9:08:10 pm
[Eric Santiago] "The opacity keyframe works the same but most of the time I am having to key the position anyway."
It takes less time to do it than explain it.
Another method (if you're keying the entire frame and not just a window) is to use the Key Output control. There are advantages and disadvantages of doing this way, but that's one of the beauties of Resolve: there's often multiple methods for accomplishing the same results.
Thomas Kaufman
on Jul 23, 2018 at 1:19:51 pm
Marc, I cannot find the Opacity control. You are exactly right in describing the effect I want. I used a power window and tracked the face i want to blur, but only need the effect for part of the clip.
Since I'm a newb, could you explain in a bit more detail?
thanks,
Thomas Kaufman, DP
Washington, DC
Glenn Sakatch
on Jul 23, 2018 at 1:30:38 pm
1- Window and Track the face for the entirety of the shot, or at least the amount you need with some handles for fading in the effect.
2- Add your blur effect
3- go to the point on your timeline where you want the window to start coming in
4- go the the keyframe editor and turn on keyframes for that node
5- go to the key control (little key button) and set the level to 0 . you should see the white matte in the key window go from white to black.
6- go to the frame where you want the blur up at full level
7- change key level to 100
8- adjust as needed
Glenn
Michael Gissing
on Jul 23, 2018 at 11:44:03 pm
A quick alternative is to just keyframe the blur value. I'm doing lots of license plate and face blurs at the moment with things coming into and out of shot. I just add a fixed or dynamic keyframe and ramp the blur value from 50 (nothing blurred) to whatever value I like the look of.
This is also handy when something moves in front of the object to blur. The shape remains but the blur ramps off and back on.
Marc Wielage
on Jul 24, 2018 at 7:24:53 am
You may find instead of keyframing the blur value itself, go to the Key menu and change the Key Output Gain value to 0. That way, if you change your mind, it's easier to vary the relative amount of the effect rather than the specific values of the blur. Of course, this works for any correction -- LGG, Log, secondaries, curves, keys, blurs, RGB, Offset, whatever.
Michael Gissing
on Jul 25, 2018 at 5:06:33 am
Thanks Marc. In this case its blur on blur off so really simple. Your method has more flexibility for more complex nodes.
