Is Dual Broadcast Monitor Playback Possible?
COW Forums : DaVinci Resolve
Reuben Fink
on Jul 9, 2018 at 12:27:14 pm
I'm trying to output to two broadcast monitors at the same time. I have two black magic boxes plugged into my MacPro and both are being detected by Davinci but I can only choose one or the other not bot simultaneously. Do you know if it's even possible to make this work?
Thanks.
OSX 10.13.5
Equipment: 2.7 ghz 12 core Mac Pro Late 2013
32 gig of ram - AMD FirePro D700 6144 MB
Michael Gissing
Re: Is Dual Broadcast Monitor Playback Possible?
on Jul 9, 2018 at 12:44:52 pm
Many Decklink cards have dual SDI output. So yes you can have dual outputs to a broadcast monitor. I have the 4K Extreme which is PCI and can do this.
Reuben Fink
on Jul 9, 2018 at 1:13:22 pm
Great thanks. Would that also apply for dual HDMI as well?
OSX 10.13.5
Michael Gissing
on Jul 9, 2018 at 1:34:32 pm
My card only has one HDMI out so no. I use SDI to HDMI converters. That way I can use my patchbays and cabling between computers in the machine room. Much simpler than having to patch HDMI and run 15 metre cables
Marc Wielage
on Jul 10, 2018 at 12:17:09 am
No, you can only use one Blackmagic card at a time. But you can use splitters and/or distribution amps to feed multiple monitors. And as Michael notes above, several Blackmagic video cards provide both HDMI and HD-SDI outputs, and you can always use an adapter to change HD-SDI to HDMI (or vice-versa). When using HD-SDI, it's generally possible to loop the output of the monitor to a second monitor (or even multiple monitors).
