CUDA need to be updated?
COW Forums : DaVinci Resolve
Duke Sweden
on Jul 7, 2018 at 11:33:36 am
Does anyone know if CUDA gets updated like GPU drivers do? It's been a year since I got this PC and installed CUDA, but it hasn't occurred to me that maybe there are new CUDA drivers that need to be installed. Nvidia's website doesn't really say anything about it. Anybody?
Dell XPS 8920
Intel i7 core 7700 build
GeForce GTX 1050ti
32 Gigs of RAM
3 7200 RPM SATA Drives
Windows 10 64-bit
DaVinci Resolve 14.3
Tero Ahlfors
Re: CUDA need to be updated?
on Jul 7, 2018 at 5:12:09 pm
Everything you need is included in the normal GPU drivers. There is a separate CUDA SDK but it is for development use only.
Duke Sweden
on Jul 7, 2018 at 7:08:39 pm
OK, and that SDK also contains the same CUDA driver that I already have installed, even though the version number is higher? One other thing, if my PC is running with no problem then should I not bother updating the GPU driver, as I read somewhere?
Thanks for responding, as usual, Tero!
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
Tero Ahlfors
on Jul 8, 2018 at 1:26:38 am
Just update your GPU drivers once in a while and you should be good to go. Note that there might be some rare problems with driversonce in a while so keep an installer handy for an older driver version.
Duke Sweden
on Jul 8, 2018 at 2:18:18 am
OK. I usually will only install recommended rather than beta drivers anyway. Thanks again!
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
