Troubleshooting - can't open XML from FCPX in DaVinci Resolve 12
COW Forums : DaVinci Resolve
Lucy Slavinsky
on Jun 5, 2018 at 6:37:32 pm
Hello all,
I am completly new to DaVinci Resolve. I am trying to move my project from FCPX to Premiere. Found some tutiorial on Youtube. Looks fairly easy. Exept.... DaVinci Resolve does not open XML. The beach ball is hanging already for an hour. The project is 5 min long. Any idea what is going on?
Thank you very much in advance.
Lucy
Shane Ross
Re: Troubleshooting - can't open XML from FCPX in DaVinci Resolve 12
on Jun 5, 2018 at 7:42:46 pm
Bringing in the XML of a SEQUENCE ONLY, right? Not an XML of the entire project? Because you can only do this with sequences.
Shane
Little Frog Post
Lucy Slavinsky
on Jun 5, 2018 at 9:48:29 pm
Thank you for your response. Actually it finally got opened. It just took more than an hour. But...some clips are messed up. Compound clips mostly. Should I breake down compaund clips in FCPX first?
Regards,
Lucy
John Pale
on Jun 5, 2018 at 11:37:26 pm
Yes. That’s a unique thing to FCPX.
Lucy Slavinsky
on Jun 6, 2018 at 1:04:29 am
Thank you!
Shane Ross
on Jun 6, 2018 at 12:33:14 am
Yes...compound clips from FCX are a big issue. They most likely are the cause of this slow import as well. Commit the edits on the FCX side, so collapse the compounds. And then export the XML. I suggest Media Managing all the footage used in the cut to an external location as well.
Shane
Little Frog Post
Lucy Slavinsky
on Jun 6, 2018 at 3:50:59 am
Thank you very much! Everything went fine finaly with FCPX and Resolve
