Unsynch clip to audio
COW Forums : DaVinci Resolve
Alex Gat
on May 29, 2018 at 1:08:31 pm
Hello,
I have been using the Auto-synch Audio based on Waveform feature, I have a couple of questions :
- used on camera clips with stereo audio, I added an independent stereo audio which makes a total of 4 tracks which I can see in the clip window question when dragging the clip it only takes the added audio, can't it take the four tracks ? Or can I even choose which one to take like when taking only audio for example.
- some synchronisation are just wrong, is there a way to undo the auto-synch ? The actual undo command works great but if used straight away. Perhaps I should ask if I can unsynch the audio afterwards ?
Thanks for your inputs.
Alex
