How to insert clip between other clips in timeline?
COW Forums : DaVinci Resolve
Jacek Antek
on May 16, 2018 at 8:28:38 am
Hi Guys,
like in the topic how to insert clip between other clips in timeline?
I want to insert black tile with text between clips...
Thank you for help,
Jacek
Tero Ahlfors
Re: How to insert clip between other clips in timeline?
on May 16, 2018 at 10:45:29 am
Insert edit. Read the manual.
Jacek Antek
on May 16, 2018 at 10:46:14 am
Anyone else?
Jacek
Joseph Owens
on May 16, 2018 at 5:28:53 pm
"Insert" edit is the correct answer.
There is another type of edit called "over write" which substitutes your trimmed source media into the timeline "over-writing" the previous clip. If you are clicking and dragging media, this can be tricky to differentiate. In versions of Final Cut Pro, there was a directional arrow that indicated what action would be taken. This depended on whether the release point was above or below a criteria line superimposed on the layer.
jPo, CSI
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Jacek Antek
on May 17, 2018 at 6:53:20 am
Thank you very much Joseph !
Insert edit is working for me !
Than you for help and support,
Best,
Jacek Antek
Peter Alessandria
on Sep 4, 2018 at 11:18:27 am
So the problem with Insert edit it two fold:
1. Let's say I am only inserting the video portion of a clip from the trimmer window between two other video clips. There's no way to only insert the video portion of the clip
2. More importantly, the track below is split at the insert point. This is unwanted (e.g. a music soundtrack).
So how do I insert a clip between two other clips on the timeline without those unwanted effects?
http://www.greatproductshots.com
http://www.superstarheadshots.com
http://www.peteralessandriaphotography.com
Laurent Fluttert
on Sep 5, 2018 at 9:53:55 am
This is basic editing. Of course there are several ways to do what you try to achieve. You could do it like this:
- select the part of the video you want to edit into your timeline by setting an in and an out marker on the source.
- deselect audio tracks on the left of your timeline so that no audio is presented to the timeline (red boxes around A1, A2 and so on.
- make the audio tracks in the sequence inactive by deselecting the boxes with <> in it (otherwise silence will be inserted).
- press Insert, the fifth button from the left below your source window . You can also drag the clip into the timeline.
Done.
