DaVinci Resolve 15 beta 2 is now available for download
COW Forums : DaVinci Resolve
Peter Chamberlain
on Apr 26, 2018 at 6:16:35 am
We are pleased to announce that DaVinci Resolve 15 beta 2 is now available for download from our support web site.
https://www.blackmagicdesign.com/support/family/davinci-resolve-and-fusion
Important note: For those using the disk database, DaVinci Resolve 15.0b2 requires a database upgrade from DaVinci Resolve 15.0b1. Regardless of which database type you use we strongly recommend that you backup your existing database (both DiskDB and PostgreSQL) before performing any upgrades.
For the full DaVinci Resolve 15 feature list, FAQs and information about upgrading from 12.5 or 14, please review
https://forum.blackmagicdesign.com/viewtopic.php?f=21&t=71881
This beta 2 update includes
Sound libraries can now also be created on Resolve Disk Databases
Improved subtitles with basic support for HTML text formatting
Improved support for audio playback for clips with variable speed changes
Improved memory usage when using Gaussian Blur in the Fusion page
Updated live preview in LUT Browser to apply the LUT on the current node
Addressed an issue where loading an old project backup and switching timelines would sometimes crash
Addressed an issue where setting a custom cache path would sometimes fail to back up the project correctly
Addressed an issue where the shortcut for Import Media would not work correctly
Addressed an issue where hovering on a filmstrip in a floating Media Pool bin would not perform the live preview
Addressed an issue where copying clips with cross fades would sometimes cause a crash
Addressed an issue where typing period or comma in timecode entry would incorrectly result in edit operations on Mac
Addressed an issue with the in point when importing timelines with edits with large speed changes
Addressed an issue where replacing a clip in the Media Pool would not update the clip name correctly
Addressed an issue where exiting Cinema mode would sometimes incorrectly reset the position of the main application window
Addressed an issue where navigating clips, keyframes or markers in the Edit page would result in an audio preview of the frame
Addressed a crash when adding a Text+ title to the timeline and enabling video field processing
Addressed an issue where some Fusion comp clips would show incorrect frame previews when cached
Addressed an issue where switching to the Fusion page would result in a crash on certain macOS systems
Addressed a crash when adding an EXR with a custom channel to the Fusion page
Addressed an issue where previewing title templates in dual screen layouts would behave incorrectly
Addressed inconsistent defaults for vertical alignment anchor in the Text3D tool in the Fusion page
Addressed a crash when render caching a node and enabling video field processing
Addressed an issue where OpenFX applied inside a compound node would not be persisted correctly
Addressed an issue where it was possible to change OpenFX parameters in a locked node
Addressed an issue where Cleanup Node Graph would result in incorrect spacing
Addressed an issue where FairlightFX plugins could not be accessed on Linux
Addressed an issue where the Noise Reduction FairlightFX plugin could not be accessed on Windows
Addressed an issue where moving audio tracks up or down would not retain the audio scroller selection
Addressed an issue where the Normalize Audio Levels dialog could not be invoked from some clips in the Fairlight page
Addressed an issue where certain USB audio output devices would not be recognized on macOS
Addressed an issue where automation on 2D Pan would alter the Front/Back positions
Addressed an issue where the timeline timecode would not be sent correctly over SDI on the Fairlight page
Addressed an issue where dragging a clip from the Media Pool to the Fairlight timeline would sometimes create an additional audio track
Addressed an issue where applying certain audio effects on a clip would result in glitches at the end of the clip
Addressed an issue where changes in the Fairlight page would sometimes not be persisted in a collaboration project
Addressed an issue where changing the clip name in Clip Attributes window would not reflect on the Fairlight timeline
Addressed an issue where DCP folders with multiple clips would not be decoded correctly
General performance and stability improvements
