Imported jpg into gallery. Applied to footage. No change
COW Forums : DaVinci Resolve
Duke Sweden
on Apr 18, 2018 at 2:01:27 am
I like to sum up my problems in the subject, but, to flesh it out a bit, just out of curiosity I grabbed a photo with a distinct color grade and imported it into my gallery. I then dragged it onto my uncorrected node and, voila!, nothing happened. What am I doing wrong? The import is a jpg. Does it have to be a .dpx file?
Dell XPS 8920
Intel i7 core 7700 build
GeForce GTX 1050ti
32 Gigs of RAM
3 7200 RPM SATA Drives
Windows 10 64-bit
DaVinci Resolve 14.3
Tero Ahlfors
Re: Imported jpg into gallery. Applied to footage. No change
on Apr 18, 2018 at 3:28:41 am
What are you expecting to happen? You can bring in stills and use them as reference to try and match grades. There's no drag and drop automagic mystery grade feature. You can get a grade from a saved still but that file needs to be exported from Resolve with the node structure used to make the particular grade.
Marc Wielage
on Apr 18, 2018 at 6:07:20 am
The grade is the accompanying DRX file; a DPX (or JPG or whatever) has no correction in it per se. The Gallery needs both a DPX and a DRX to provide a still reference and a stored color-correction, by design.
Duke Sweden
on Apr 18, 2018 at 11:19:57 am
Ah, ok. I was thinking there was that same color matching feature that was in Speedgrade. It was used to match up camera shots but you could also import TGA files and match your video up to the look in those. And that, Tero, was what I was expecting to happen.
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
Tero Ahlfors
on Apr 18, 2018 at 11:30:51 am
There is a shot match feature but it doesn't work in that way. Page 708 in the latest Resolve 14 manual.
Duke Sweden
on Apr 18, 2018 at 2:29:27 pm
Then that's not what I was looking for.
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
Ole Kristiansen
on Apr 21, 2018 at 5:06:06 pm
3D LUT Creator
Look from the time 08:17
Duke Sweden
on Apr 21, 2018 at 7:00:35 pm
Already got it, never use it, but thanks, Ole. Good to know you're still looking out for me :-)
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
