Generating Proxy/Optimized footage automatically as clips are importing
COW Forums : DaVinci Resolve
Adam Berch
on Mar 12, 2018 at 7:58:58 pm
I am using DaVinci 14 on an imac
Is it possible that when I import 4K, Ultra HD or HD footage that it automatically generates Optimized/Proxy clips as it's importing so I don't have to do it later?
Duke Sweden
Re: Generating Proxy/Optimized footage automatically as clips are importing
on Mar 21, 2018 at 2:34:13 am
Excuse my ignorance but it only takes like a second to import any number of clips into Davinci, hardly enough time to also generate Proxy clips. As soon as you drag them into the Media Pool, they're imported.
You may as well take that extra second to click on "Generate Optimized Media". I'm assuming you're new to Davinci. If not, then excuse this clown response. I'm only trying to help ;-)
Dell XPS 8920
Intel i7 core 7700 build
GeForce GTX 1050ti
32 Gigs of RAM
3 7200 RPM SATA Drives
Windows 10 64-bit
DaVinci Resolve 14.3
Glenn Sakatch
on Mar 21, 2018 at 5:31:50 pm
I'm with Duke...importing is pretty much instantaneous. Its not creating new media, you are simply telling Resolve where the clips are. From there, select the clips and create your optimized media....then wait.
Glenn
Duke Sweden
on Mar 21, 2018 at 7:36:38 pm
Unless....he meant while importing them from the SD card onto his PC using Resolve? Maybe? In which case I think the answer is still no. But I could be wrong. Just trying to cover all the bases. I'm "Delivering" right now so I can't check if that's an option.
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
