Copy and paste OpenFX filters & attributes?
COW Forums : DaVinci Resolve
Russ Johnson
on Mar 3, 2018 at 4:46:51 pm
I can see how to copy and paste video attributes from a clip on a timeline to other clips, but I can't see how to copy an OpenFX filter (in this case Soften & Sharpen) and its settings applied to a clip and paste those to other clips in the timeline. Any help is appreciated.
Thanks.
Glenn Sakatch
Re: Copy and paste OpenFX filters & attributes?
on Mar 4, 2018 at 8:03:55 pm
You would select the node with the ofx plugin ..ctrl c or command c... and then paste it onto a new node on another clip. Or grab a still of a clip if it only has the ofx plugin you want.
Glenn
Marc Wielage
on Mar 5, 2018 at 1:12:57 am
[Russ Johnson] "I can see how to copy and paste video attributes from a clip on a timeline to other clips, but I can't see how to copy an OpenFX filter (in this case Soften & Sharpen) and its settings applied to a clip and paste those to other clips in the timeline. "
There's a couple of ways to do it:
1) highlight the clips you want to change. Add the clips into a New Group by right-clicking the thumbnail -- you could call the group "Soften-Sharpen." In either Pre-Clip Grade or Post-Clip Grade, create a node and cut-and-paste the settings you want from the Soften & Sharpen OFX plug-in.
2) Have a node at the very end of the node graph with the Soften & Sharpen OFX grade (only) in it. Now, highlight all the clips you want to change. Under the Color menu, choose "Append Node to Selected Clips." Now, those shots will have a new node at the end with only the Soften & Sharpen correction added.
What can also be helpful is to have a fixed node tree that has (say) a dozen or two dozen pre-labeled nodes for every single shot, even if most of them are de-activated. This way, if you decide to make a change on a specific node, you just change that one node and ripple it to the entire timeline (or whatever shots you need to change).
Russ Johnson
on Mar 5, 2018 at 4:48:45 pm
Thanks for the replies guys. I follow on some limited level, but it's mostly "Greek" to me - old Avid/FCP7 habits die hard.
Consequentially, it looks like I'm going to be in the market for some on-line Resolve training. If you have any recommendations, let me know.
Thanks again.
-Russ
Russ Johnson
on Mar 5, 2018 at 5:38:04 pm
Hi again,
Just blundered through putting a LUT and applying the OFX "Soften & Sharpen" on a node. Really like the node work flow so far.
-Russ
(neophyte Resolve user)
