Thumbnail Clips in Bins from range selection in out instead of first frame
COW Forums : DaVinci Resolve
Mariano Puppo
on Feb 28, 2018 at 5:35:08 pm
Hi people,
Sorry if this is a dumb question, but I can't find a easy way to change all thumbnails of the clips inside a bin using the in selection instead of the footage first frame. For example I did a preselection I create a new bin, I drag all those cuts into the bin where some clips are from the same footage but different in-out moments of the video file but in the bin all thumbnails are the same for that footage it doesn't respect the range selection. I can't go manually scrubing each clip to just set a new thumbail I would like to know if there is an automatic way to switch all thumbnails of a bin into the first frame of the in-out selection instead of the first frame of the file.
