Resizing Mini DV footage in resolve
COW Forums : DaVinci Resolve
Ben Anderson
on Feb 26, 2018 at 6:49:46 pm
I primarily work with mini dv cameras and when ever import the footage into the time line i get these two black bars at the top and bottom when i resize the video. is there a way to get around this? any help is greatly appreciated!
thanks and hope you all are well.
-Ben
Michael Gissing
Re: Resizing Mini DV footage in resolve
on Feb 27, 2018 at 11:29:46 pm
Check the clip attributes. Resolve probably hasn't correctly guessed the aspect ratio.
DV is such an awful old codec with interlacing and other issues. Aspect is one of them. You might have to manually tweak the aspect. Once you do one you can copy and paste those via paste attributes to multiple clips
