Will this PC handle 4K editing with Resolve?
COW Forums : DaVinci Resolve
Thomas Kaufman
on Feb 21, 2018 at 12:54:54 am
I'm looking to buy a PC with the following specs. Does it look like it can handle Resolve, or does anyone see a problem?
thanks,
Intel Core I7-8700K (6-Core, 12MB Cache, Overclocked upto 4.6GBz across all cores) with liquid cooling.
NVIDIA GeForce GTX 1080 Ti with 11GB DDR5X Founders Edition Video Card
16 GB Dual Channel DDR4 at 2666MHz (2x8GB and 2 empty memory slots for future expansion)
256GB M.2 PCIe Solid Statye Drive
2TB 7200RPM SATA 6Gb/s hard drive
802.11ac + Bluetooth 4.1, Dual Band 2.4&5 GHz Wi-Fi
850 Watts EPA Bronze Power Supply Unit with Liquid Cooled Chassis.
Alienware Over Clocking Software
Windows 10 Home
Logitech wireless back-lit illuminated keyboard with track-pad K830
Thomas Kaufman, DP
Washington, DC
Duke Sweden
Re: Will this PC handle 4K editing with Resolve?
on Feb 21, 2018 at 3:18:35 am
Check my specs, below. Nowhere near what you're looking at, and it handled Resolve and everything I threw at it up until the GH5 firmware update and 400mbps ALL-I codec video files.
Dell XPS 8920
Intel i7 core 7700 build
GeForce GTX 1050ti
32 Gigs of RAM
3 7200 RPM SATA Drives
Windows 10 64-bit
DaVinci Resolve 14.3
Michael Gissing
on Feb 21, 2018 at 10:26:00 pm
Resolve will run on a laptop but your computer spec depends more on what real time performance with the codecs and pixel aspects you need to work at. Personally I prefer 32 gig of RAM and an onboard RAID that can handle the speeds I need. I also have USB-c/ Thunderbolt 3 on my mobo.
Shane Ross
on Feb 21, 2018 at 10:37:43 pm
You really should get more RAM...16GB is bare minimum. 32 is better.
And I don't know if Resolve will run on Windows HOME edition. It's high end professional software and from my research on the matter, Blackmagic Design said that it requires Windows Professional.
Shane
Little Frog Post
Duke Sweden
on Feb 21, 2018 at 11:15:10 pm
I concur on the 32 gigs, but I can also confirm that Resolve runs with no problems on Windows 10 Home.
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
