DaVinci Resolve 14.3 is now released
COW Forums : DaVinci Resolve
Peter Chamberlain
on Feb 2, 2018 at 12:56:29 am
DaVinci Resolve 14.3 is now released on our support web page.
https://www.blackmagicdesign.com/support/family/davinci-resolve-and-fusion
This is a no charge update for all existing customers.
Important Information regarding Database Management
DaVinci Resolve 14.3 requires a database upgrade from previous versions. We strongly recommend that you backup your existing database (both DiskDB and PostgreSQL) before performing an upgrade. If you are in the middle of a project you may wish to export that project as well prior to updating the database.
What's new in 14.3
Added support for the Blackmagic Design URSA Broadcast camera
Added support for RAW footage from the Sony Venice/CineAltaV camera
Improved the quality of thumbnails in the Media Pool and Edit page timeline on retina monitors
Added support for reading Panasonic Varicam metadata when importing footage
Added support for exporting Sony color space and gamma metadata when encoding to MXF
Added support for RED SDK v7.0.6
Addressed an issue where the audio section in the Deliver page would default to timeline track instead of the Main bus
Addressed an issue where editing a transition could sometimes cause a crash
Addressed an issue where syncing video to audio with a different sample rate results in incorrect audio sync and pitch audio
Addressed an issue where changes to the Mixer UI layout would not get saved in a dual screen setup
Addressed an issue where pressing arrow keys to move volume keyframes would not work after opening the keyframe curve editor
Addressed an issue with the option to pick which node to select when switching clips
Addressed an issue where a project would fail to save after deleting a group
Addressed an issue where a project would fail to save after specific undo/redo operations
Addressed an issue with UI artifacts in the DaVinci Resolve Studio activation window
Addressed an issue where projects with LUTs would not get exported correctly on Windows
Addressed an issue where the current project could not be copied between databases
Addressed an issue where relinking to TIFF files with a higher bit depth would result in a crash
General performance and stability improvement
