settings to grade a Movie in Davinci
COW Forums : DaVinci Resolve
Laura Fernandez
on Jan 29, 2018 at 9:32:44 am
I have some questions regarding to grading a movie in devinci
I use a Monitor Zunzheng AM420 that offers the possibility to switch the colorspaces. I normally use rec709 but for the movie my intention is to switch it to DCI-P3 colorspace.
In the Color Management in Davinci i was also gonna switch the Timeline color space from Rec.709 Gamma 2.4 to DCI-P3
To export i was gonna use the easy DCP option
Questions:
1) Is it enough to switch the monitor from 709 to DCI-P3? Or am I suppose to calibrate it again once its already in DCI-P3?
2) Switching the Timeline color space to DCI-P3 is correct? Or should I change it to DCI- XYZ?
3) Exporting easy DCP in the delivery page is correct?
Thanks!!!!!!
Tero Ahlfors
Re: settings to grade a Movie in Davinci
on Jan 29, 2018 at 9:55:41 am
[Laura Fernandez] " but for the movie my intention is to switch it to DCI-P3 colorspace."
Why?
Laura Fernandez
on Jan 29, 2018 at 10:13:43 am
becasue as far as I know (and i might be completly wrong) the DCI-P3 is the color space I "should" use to grade a movie that is gona be released.... but i might be wrong... thats why I ask ☺
Tero Ahlfors
on Jan 29, 2018 at 11:08:23 am
[Laura Fernandez] " the DCI-P3 is the color space I "should" use to grade a movie that is gona be released.... "
Nope. The end result needs to be in DCI XYZ when you make a DCP. There are a lot of features that are graded in Rec709 and then converted when it's done. The thing about DCI-P3 grading is that it should be done with a projector in a proper DI theater. You can't emulate projector reflectance on a monitor.
Unless you really know what you're doing you'd probably be better off by grading in Rec709.
Joseph Owens
on Jan 29, 2018 at 4:02:10 pm
If you want to work from a colorspace that lends itself to various export standards, then that is what the ACES color management approach offers.
You will not be working, strictly speaking, in any specific release format -- what you will be doing is monitoring in the colorspace currently selected. Picking 709 under that system is perfectly acceptable if you are monitoring the output on a 709-calibrated display. The same would be true if you picked P3 and you were working in a projected P3 environment. That's how it is supposed to work.
To learn more, search for "Display-referred" color management practices.
jPo, CSI
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Laura Fernandez
on Jan 30, 2018 at 2:59:30 am
Noted. Thanks!
Laura Fernandez
on Jan 30, 2018 at 2:58:25 am
So that means i better work in 709 and then the easy DCP will do the proper conversion to DCI-P3 XYZ ?
Thanks for the answer!
