replacing footage
COW Forums : DaVinci Resolve
Bruce Gaber
replacing footage
on Jan 26, 2018 at 9:20:42 pm
I'd like to replace footage I've been working on in DR with an update version I've modified in AE and rendered out. Is this possible in DR? I understand we can "relink" media, but that does not seem to be the same process.
Bruce
Photographer / Motion Graphics Artist
Vision Rising
vimeo.com/BodhiBruce
visionrising.com
Dance Without Reason
Tero Ahlfors
Re: replacing footage
on Jan 26, 2018 at 9:36:57 pm
There are many ways and pretty much all of them can be found in the manual.
Ole Kristiansen
on Jan 26, 2018 at 9:42:16 pm
Clip Replacement
Look from time 03:20
Glenn Sakatch
on Jan 27, 2018 at 5:17:27 pm
If your new clips are the same length as the originals, with the same timecode, then it is easy...even easier if you make them the same name, but put them in a "revised" folder. (Tell Resolve to look in the revised folder for these clips)
If they have different timecode (which I'm guessing they do) then it becomes much more labour intensive, as you will have to tell resolve which ones go where. If your new renders start at the exact frame you want the new clip to start at..that would be easier. If there is pad on the clips, I think you will be doing them individually, setting in points and editing them in.
Glenn
