Can you delete optimized media from multiple projects at once in Resolve?
COW Forums : DaVinci Resolve
Duke Sweden
on Jan 18, 2018 at 1:53:53 pm
I can't remember which projects I've generated optimized media for. Is there a universal Optimized file and cache deletion function to just wipe out everything? Remember, I'm an amateur, I just play at this, so it doesn't matter if I delete "necessary" files. I can just regenerate later if I need to. Which I probably won't.
Dell XPS 8920
Intel i7 core 7700 build
GeForce GTX 1050ti
32 Gigs of RAM
3 7200 RPM SATA Drives
Windows 10 64-bit
DaVinci Resolve 14.2
Tero Ahlfors
Re: Can you delete optimized media from multiple projects at once in Resolve?
on Jan 18, 2018 at 2:51:29 pm
You can delete the whole Resolve cache folder from the OS side. Unless you've given it some custom name it should be called CacheClip and it's under the folder you've set as the cache.
Duke Sweden
on Jan 18, 2018 at 3:09:53 pm
Thanks Tero. You just cleared 300 gigs from my source drive! What about optimized files? Were those also stored in the CacheClip folder?
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
Tero Ahlfors
on Jan 18, 2018 at 3:29:54 pm
That folder has all cached files (smart/user cache, transitions etc.)and all optimized media.
Duke Sweden
on Jan 18, 2018 at 4:00:23 pm
Excellent. Thanks again!
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
