Small black stripes on 3 sides of the monitor
COW Forums : DaVinci Resolve
Tom Knight
on Jan 12, 2018 at 10:19:22 am
Hello, I have the following problem: My clips are displayed in the monitor with narrow black margins. Left, right and down. Not at the top. See photo. I can only remove this false stripes by transforming the clip to a value of, for example, 1,020 using zoom. Does anyone have an idea what's wrong? Many Thanks.
DR Version 14.2 Studio
Windows 10, i7, 32 GB RAM
Tero Ahlfors
Re: Small black stripes on 3 sides of the monitor
on Jan 12, 2018 at 10:37:51 am
What are your footage dimensions/pixel aspect ratio and what are your project timeline settings?
Tom Knight
on Jan 12, 2018 at 10:40:50 am
Hi Tero, the footage dimension is Full HD 1920x1080, the timeline setting ist 1280x720.
Tom Knight
on Jan 12, 2018 at 10:43:08 am
In other programs like Avid MC or Magix VdL the problem doen't exist.
Eric Santiago
on Jan 12, 2018 at 4:01:03 pm
its nothing just aspect ratio.
you can do an output node with a little overscan.
Tom Knight
on Jan 12, 2018 at 5:26:37 pm
@Eric:
Okay, but what do you mean with "a little overscan"?
Tom Knight
on Jan 13, 2018 at 1:14:50 pm
@Eric:
You wrote: "you can do an output node with a little overscan."
Please explain me the way.
Glenn Sakatch
on Jan 13, 2018 at 5:29:52 pm
rather than doing your little zoom adjustment on each clip, do a timeline clip or output node with a resize zoom of the same amount. (the zoom is the overscan) There is nothing wrong with your current fix, but there is an easier way to do the adjustment if it is universally needed across your entire timeline.
Depending on your footage, you might be able to set your preferences/scaling control to be "full frame with crop", which would fix the shots on input, rather than output...again depending on the origin of the issue.
Glenn
Tom Knight
on Jan 14, 2018 at 10:10:22 am
Thank you very much, Glenn. Well explained, it works!
