3D text with metallic effect
COW Forums : DaVinci Resolve
Tom Knight
on Dec 21, 2017 at 2:40:29 pm
How can I apply a 3D text with metallic effect? I think that would have to go with Fusion. In the folder Templates / Shaders there is the template Anisotropic.setting. I like that very much. But how do I apply it to the text?
Michael Gissing
Re: 3D text with metallic effect
on Dec 21, 2017 at 9:32:55 pm
I use Boris Continuum 11 in Resolve for titling. I'm sure you can use Fusion but I don't know how to do that in Fusion.
Glenn Sakatch
on Dec 29, 2017 at 4:18:02 pm
In fusion, on your shading tab in the 3d text settings, you select the Material- image option, then near the bottom select the image you want to use, I would usually set the mapping to word instead of character.
Glenn
Glenn Sakatch
on Dec 29, 2017 at 4:22:50 pm
you can also select the tool button instead of image and right click on the "color image" tab, and connect to an existing tool within your flow. (limited to what tools you can use)
Glenn
