Resolve adds black bars when importing media
COW Forums : DaVinci Resolve
Allard DePallerd
on Oct 23, 2017 at 3:22:50 pm
hi Guys,
im using Resolve to convert my FS7 footage tot DNxHR, so it's easier to work with in Premiere.
But when I import my source files in the media page.. it puts black bars on top and bottom of the clip, in stead of just showing the clip as is. And when i create a timeline from my FS7 source footage, it also puts black bars on the sides. So something is going wrong when importing, and when making a timelime..
Can anyone tell me what im doing wrong (aspect ratio maybe?)
This is what it looks like in the timeline..
Tero Ahlfors
Re: Resolve adds black bars when importing media
on Oct 23, 2017 at 3:26:35 pm
What is the resolution of your source media? What's the resolution of your exported DNxHR files?
Allard DePallerd
on Oct 23, 2017 at 3:39:59 pm
The source material is 4096x2160 pixels
The exported DNxHR file is 4096x2160 pixels
so they're the same. So the timeline sequence seems to have the right resolution, but it just adds the black bars within that resolution ...
And like i said before...as soon as i import the media..it already adds the black bars on top/bottom. And it doenst seem to cut off the footage anywhere... so that's why im thinking its a problem with the aspect ratio..
Tero Ahlfors
on Oct 23, 2017 at 3:47:41 pm
Are you using the free version of Resolve?
Allard DePallerd
on Oct 24, 2017 at 7:08:42 am
Yes I am... is that the problem?
Tero Ahlfors
on Oct 24, 2017 at 7:24:42 am
The free version is limited to 3840x2160 output. Even if you use the "use source resolution" from the deliver page the file can be the same size but the image inside the file is limited to UHD output.
Allard DePallerd
on Oct 24, 2017 at 8:55:55 am
Ah that makes totally sense.. the source is 4k so when it make the footage fit in a UHD resolution.. you would get black bars on top/bottom.
Damn, kinda obvious...
follow up question.. if i want to convert my FS7 footage to DNxHR.. (lossy/lossless)..which one would i need to choose?
I was thinking DNxHR HQX... but that makes my files 3 times bigger..so im thinking that might be overkill and I need a lesser codec.. but I dont want to loose quality..
please advise.
Tero Ahlfors
on Oct 24, 2017 at 9:03:02 am
I would use one with similar bitrate and chroma subsampling for the footage you've shot. Also better formats take more space, that's just the way it is.
Allard DePallerd
on Oct 24, 2017 at 9:46:30 am
These are the ones i can choose from for my 4K footage
Avid DNxHR 444 4096 x 2160 4:4:4 10 60 3730
Avid DNxHR HQX 4096 x 2160 4:2:2 10 60 1866
Avid DNxHR HQ 4096 x 2160 4:2:2 8 60 1866
Avid DNxHR 444 4096 x 2160 4:4:4 10 24 1492
Avid DNxHR HQX 4096 x 2160 4:2:2 10 24 746
Avid DNxHR HQ 4096 x 2160 4:2:2 8 24 746\
My footage is 4:2:2, 10bit,, 490mbps and 50FPS
So the only one that ticks all my source footage's boxes.. is the
right?
Duke Sweden
on Oct 24, 2017 at 1:06:21 pm
If you have Premiere Pro, why don't you create your proxies in Media Encoder? Just curious.
Dell XPS 8920
Intel i7 core 7700 build
GeForce GTX 1050ti
32 Gigs of RAM
3 7200 RPM SATA Drives
Windows 10 64-bit
Premiere Pro CC 2017 v.11.0
Allard DePallerd
on Oct 24, 2017 at 2:16:44 pm
Fair question...
But I have tried that, but ive been getting nothing but errors in media encoder. I have tried numerous settings, but its just really flaky and its giving me error after error.
And for some reason. .. the Resolve encoder just works perfect for me..
Mike Most
on Oct 24, 2017 at 7:33:46 pm
If it works so perfectly, why not just pay for it and solve your problem? The full version is only $299....
Allard DePallerd
on Oct 25, 2017 at 7:48:31 am
Well, I didnt know that my problem was because i didnt have the paid version..so that the reason why i havent thought about buying the programme.. Secondly.. I will only use Resolve to encode my files.. I like to edit my projects in Premiere. So i'd be paying 300 bucks for a gloryfied videoconverter.. which seems a bit much. But i might do it anyways cause I dont really have a choice i think
