"Your GPU Memory is Full", but Resolve continues to render
COW Forums : DaVinci Resolve
Duke Sweden
on Sep 27, 2017 at 2:28:13 pm
I expected to get that error message since I was doing an experiment with Neat Video on 4 clips and timeline set to 4096x2160 DCI. I don't know if someone will answer this before the render is complete (55 minutes left), but is Resolve actually rendering or will I get an error message at the end saying render could not complete, or words to that effect?
Kind of odd that I don't have enough VRAM yet Resolve continues to render.
Dell XPS 8920
Intel i7 core 7700 build
GeForce GTX 1050ti
32 Gigs of RAM
3 7200 RPM SATA Drives
Windows 10 64-bit
Premiere Pro CC 2017 v.11.0
Joseph Owens
Re: "Your GPU Memory is Full", but Resolve continues to render
on Sep 27, 2017 at 2:49:21 pm
[Duke Sweden] "Kind of odd that I don't have enough VRAM
GeForce GTX 1050ti"
As if there weren't enough mysteries. Although it is important, your onboard RAM is not that significant; it is the GPU VRAM statistic - in your case, 4GB - that is causing this warning. Stacking up several frames of 4096 on a single 1050Ti is going to exhaust that resource very quickly, and that is what is happening if you are adding a third-party OFX plugin.
Your render probably won't crash, but the frame rate is obviously in the dumpster.
jPo, CSI
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Duke Sweden
on Sep 27, 2017 at 2:51:05 pm
Joe, I already knew about the lack of VRAM. My question was, will I have a successful render when it's done, since it's still rendering. I've only got 1:44 left to find out.
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
Duke Sweden
on Sep 27, 2017 at 3:17:16 pm
UPDATE: Clip rendered perfectly, no dropped frames. Take THAT, "GPU Memory is full" error message!
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
Dmitry Kuznetsov
on Oct 27, 2017 at 8:07:14 pm
I had the same error messages then used this plugin. But I had some frames rendered with artifacts. So be careful.
Color Grading Specialist / DI Colorist / DaVinci Resolve Colorist
For business inquiries:
http://contact.photodmitry.com
Duke Sweden
on Oct 28, 2017 at 3:45:52 am
I actually created a VBScript that clears my RAM cache without having to reboot. Just right click and "open in command prompt". Happens instantly and it frees up all my RAM. I then do my render which so far has gone off without a problem, even when tested with heavy tweaks. And I do mean heavy.
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
Ole Kristiansen
on Sep 27, 2017 at 3:18:28 pm
If anyone can answer this - I would like to ask about the winning numbers in the lottery !
Duke Sweden
on Sep 28, 2017 at 12:24:43 pm
If I were you I'd pick a more popular thread to ask that question ;-)
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
Glenn Sakatch
on Oct 28, 2017 at 3:14:07 pm
I've had it happen both ways...renders that worked, and renders that were all glitchy, so just double check.
Glenn
Duke Sweden
on Oct 29, 2017 at 11:35:55 am
Thanks, Glen. I always do. Again, I'm just a hobbyist, I don't have clients waiting on me, and my videos are usually no more than 4 or 5 minutes long. Easy to check for glitches and stuff. Cheers!
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
