Best codec to render to when sending to Premiere Pro
COW Forums : DaVinci Resolve
Duke Sweden
on Sep 22, 2017 at 10:47:36 pm
If I do my color grading in Resolve, which lossless codec/wrapper should I deliver to so I can edit in Premiere pro? I checked, Tero, it's not in the manual.
Dell XPS 8920
Intel i7 core 7700 build
GeForce GTX 1050ti
32 Gigs of RAM
3 7200 RPM SATA Drives
Windows 10 64-bit
Premiere Pro CC 2017 v.11.0
Kevin Rag
Re: Best codec to render to when sending to Premiere Pro
on Sep 22, 2017 at 11:50:00 pm
Hi Duke,
A lot of my PC based industry friends use Cineform. Have you tried it? Or DNxHD is another good editing codec. I'm ProRes all the way since I'm on a mac.
K
Chris Wright
on Sep 23, 2017 at 12:47:52 am
are you using an XML to retain edit points? yea, cineform level 4/5 or dnxhr are really, really high quality, close to lossless.
Michael Gissing
on Sep 23, 2017 at 1:58:58 am
I stick to DNx codecs. It has the added bonus that it is also the codec of choice if returning to Avid. DNx in mxf wrappers should be the default delivery codec as it is open and available, not closed and proprietary like ProRes.
Tero Ahlfors
on Sep 23, 2017 at 5:56:39 am
If you absolutely need a lossless format I would go with DPX or EXR. The filesize will be huge but it's lossless. Otherwise 10 bit DNxHD/DNxHR as mentioned in other comments. They aren't straight up lossless but they are "visually lossless".
Duke Sweden
on Sep 23, 2017 at 11:59:48 am
That's what I thought. DNxHD or HR. I was just wondering why Resolve defaulted to Quicktime in the Delivery section. It's not like the list was in alphabetical order.
Thanks, everybody.
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
Glenn Sakatch
on Sep 23, 2017 at 3:11:56 pm
I've been doing DNX444 to Premiere for 1 particular project, but because of either my lack of knowledge on how to change the color interprelation, or Premiere's lack of ability to change how it reads a file, I select full levels in Resolve for my output. Blacks should then look proper in Premiere. 444 should be full, but I find Resolve, if left in Auto, outputs it at Video level, perhaps reading the DNX tag as more important than the 444 tag.
Either way, set your levels to Full if going to Premiere.
Glenn
Duke Sweden
on Sep 24, 2017 at 11:13:46 am
Excellent. Thanks!
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
