Why so complicated to do green screen keying in Resolve?
COW Forums : DaVinci Resolve
Duke Sweden
on Sep 17, 2017 at 11:42:33 am
I can't understand why such an advanced piece of software like Resolve can't come up with an easier way to green screen. I love the program, have switched from Premiere Pro, but in that program I merely place a keying plugin on the clip, choose the green, and it's gone, with some minor tweaking. All this inverting and highlighting and creating an alpha node. And still I'm not impressed with the results. It's kind of ridiculous for what this software can do.
Dell XPS 8920
Intel i7 core 7700 build
GeForce GTX 1050ti
32 Gigs of RAM
3 7200 RPM SATA Drives
Windows 10 64-bit
Premiere Pro CC 2017 v.11.0
Simon Ubsdell
Re: Why so complicated to do green screen keying in Resolve?
on Sep 17, 2017 at 1:11:22 pm
Take your shot into Fusion using Fusion Connect and use either Primatte, Ultra Keyer or the new Delta Keyer (or a combination of all three) - you will get better results that way than with any other method.
It's what Fusion is made for.
Simon Ubsdell
tokyo productions
hawaiki
Duke Sweden
on Sep 17, 2017 at 8:11:17 pm
Did not know that. Thanks.
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
Simon Ubsdell
on Sep 17, 2017 at 8:14:32 pm
You might find this tutorial useful - it takes you through the basics of using Fusion Connect:
Simon Ubsdell
tokyo productions
hawaiki
Duke Sweden
on Sep 17, 2017 at 8:56:59 pm
Thanks. I've actually found that in 14 it's a LOT easier. Create my serial node, create alpha channel on output, select my green area with qualifier (3D), then invert. Despill if necessary and I'm getting a much better key than I ever got in Premiere Pro without much tweaking of the edges.
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
Tom Matthies
on Sep 18, 2017 at 9:55:27 pm
I'm trying to use Boris' Chroma Key Studio in Resolve but something is not right. I can pull a clean key, but my background is black rather than showing the layer below it. I'm trying to do it just by dropping the filter on the clip itself in the timeline. Adding a serial node alpha channel didn't seem to work either.
Any other Boris users out there with suggestions?
Not my monkeys. Not my circus.
Michael Gissing
on Sep 18, 2017 at 11:14:12 pm
On the node with the OFX plugin, you also have to right click and select 'use OFX alpha'
Duke Sweden
on Sep 19, 2017 at 6:05:05 pm
Good to know in case Resolve's built in keying process ever fails me. Cheers!
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
