Resolve not rendering in full screen? resolve lite limitation?
COW Forums : DaVinci Resolve
Ricky Milling
on Sep 2, 2017 at 4:51:17 pm
http://imgur.com/a/tfCp9
Trying to export DPX and this is what happens?
Clips is 3792x3160
Timeline is 1080p
Need to output (for vfx purposes) at 3792x3160.
Is this down to Resolve Lite limitations?
Dmitry Kitsov
Re: Resolve not rendering in full screen? resolve lite limitation?
on Sep 2, 2017 at 6:30:24 pm
Hello, Ricky,
DaVinci Resolve is limited to 3840x2160 output raster. If you are attempting to Render at source resolution you will get a clip at source resolution but with the image scaled down to maximum of 3840x2160 dimension.
You will need to use DaVinci Resolve Studio to overcome this limitation
Dmitry Kitsov,
Blackmagic Design technical support agent
Ricky Milling
on Sep 3, 2017 at 11:40:41 pm
Ok i understand but still the file being outputting is 2795x3160 (ala the raw footage) has massive black bars all around the footage. I have attached the image in
How it looks in resolve
When opened in premiere
All of those black borders and embedded and im struggling to understand why?
Massimo Alberto Croce
on Sep 4, 2017 at 2:23:25 pm
it seems to be anamorphic.
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com
Peter Chamberlain
on Sep 5, 2017 at 10:35:49 am
Start by putting the maximum res in the timeline settings, 3840x2160. Then set the scaling to be zoom to fit. The if anamorphic in the media pool set the clip attributes pixel aspect ratio to 2:1
