Premiere to DaVinci Scale Attributes
COW Forums : DaVinci Resolve
Jennifer Gaida
on Jul 20, 2017 at 10:33:12 pm
Since Premiere uses a scale of 0-100 for resizing, is there a user-friendly way to convert Premiere's scale and repo numbers to ones that adhere to Davinci Resolves? I'm specifically interested in figuring out to how do this manually so no need to suggest XML's or anything that retain attributes. Thank you!
Michael Gissing
Re: Premiere to DaVinci Scale Attributes
on Jul 21, 2017 at 3:47:19 am
Resolve first scales and then applies resizing info. Try in Premiere getting it to scale the image first before any resize. It should then track.
I've had this before and suggested to editors to test and see if that works so if it does please let us know as I've not received feedback. I haven't used the latest Pr but CS6 from memory you could select a clip and a context menu gave you scale to timeline before you then resize. Curious if it does that without changing the 0-100 numbers. particularly useful for stills moves etc.
