How can I Jump between shots away from edit points?
COW Forums : DaVinci Resolve
Diego Burlando
on Jul 4, 2017 at 4:02:07 am
Does anyone know how can I jump between clips but not in edit points? I'm trying to check a XML timeline with the reference clip but jumping between frames away from edit points.
Thanks.
Peter Chamberlain
Re: How can I Jump between shots away from edit points?
on Jul 4, 2017 at 2:15:40 pm
If you have an edit point selected, the previous/next will select edit points. If you have a clip selected, it will select the next clip.
Diego Burlando
on Jul 4, 2017 at 3:25:01 pm
Thank you, Peter!
But my question aimed to find a way to jump the playhead not between edit points but somewhat in the middle of each clip. I found that (edit points selected) up and down arrows and then Shift right arrow moves the playhead where I wanted.
