Vertical Wipe transition for DaVinci Resolve 12.5
COW Forums : DaVinci Resolve
Allen Zagel
on Jun 25, 2017 at 12:10:58 am
Where can I find a Vertical Wipe transition for DaVinci Resolve 12.5. I need it for an easy way to animate a map showing a route. The wipe in Resolve is horizontal. I don't see how can change that one.
Allen
Glenn Sakatch
Re: Vertical Wipe transition for DaVinci Resolve 12.5
on Jun 25, 2017 at 4:29:12 pm
you could put the clean map on V1, the map with the line on V2, add an alpha output on V2, and animate a power window to expose the line on V2. This would allow a much more dynamic line to be drawn.
Glenn
Marc Wielage
on Jun 26, 2017 at 1:53:42 am
It's not real intuitive, but the EDGE WIPE transition is rotatable so you can do either a horizontal wipe or a vertical wipe or any Angle degree shift you want. 90° or -90° should give you what you want.
