Possible to select only moving pixels?
COW Forums : DaVinci Resolve
Adriano Castaldini
on Mar 12, 2017 at 12:27:06 am
Hi everyone,
I'd like to grade separately the subject and the background. Let's say that the background is still and the subject is moving, it should be easy to select the subject-only if there were a tool for selecting only the moving pixels (or only the still pixels). Do you know if there is something similar in Davinci Resolve?
Thanks for your help.
Toby Tomkins
Re: Possible to select only moving pixels?
on Mar 12, 2017 at 10:54:25 am
The only way I can think of is to;
Copy the clip to v2. Go to blending mode, select difference for blending mode, apply noise reduction and tweak gain, turn B&W, export that clip as something high quality like prores4444. Delete copy of clip on v2. Use that clip as an external matte to drive a correction node on v1. You will probably have to tweak the matter to get desired results, maybe with blur etc. Good luck.
Adriano Castaldini
on Mar 12, 2017 at 3:36:47 pm
Wow... Smart solution! Thanks so much Mr. Tomkins
Toby Tomkins
on Mar 14, 2017 at 9:09:54 am
No worries. It was an interesting question.
