Resolve 12.5-OP1A-DNxHR HQ
COW Forums : DaVinci Resolve
Bill Ravens
on Feb 26, 2017 at 5:37:08 pm
Apparently, Resolve 12.5 still doesn't create OP1a(MXF) wrapped DNxHR HQx (4k, 4.2.2, 10 bit) files?
The output has diistorted colors and a green bar across the top of the frame.
Eric Rosen
Re: Resolve 12.5-OP1A-DNxHR HQ
on Feb 26, 2017 at 6:52:18 pm
Assuming you are in Windows.
Nvidia driver issue, install version 373.06, that will fix the issue.
Eric Rosen
http://www.colormatters.tv
p. 206.552.9806
Bill Ravens
on Feb 26, 2017 at 8:51:16 pm
Interesting. But, I am already using nVidia driver v 375.86. Will rolling back to an earlier version really help?
Eric Rosen
on Feb 26, 2017 at 8:55:20 pm
Worked for me. You can always go back to your current driver if needed.
Eric Rosen
p. 206.552.9806
Bill Ravens
on Feb 26, 2017 at 10:14:15 pm
I exported an OP1A DNxHR HQx file from Avid Media Composer and it does NOT have this issue. The issue appears to be with Resolve.
EDIT: I installed your recommended nVidia driver; and, as you said, that fixed things. I guess DaVinci hasn't caught up with the latest nVidia releases.
