FCPX and Resolve vectorscopes showing different images
COW Forums : DaVinci Resolve
Maria Troitskaya
on Dec 16, 2016 at 8:56:52 pm
Hello. I'm new to Davinci Resolve. I made a test video file in FCPX just to be shure I see it the same way in FCPX' and Resolve's vectorscopes. And there is a difference between what I see. How can I fix that?
Thank you.
10879_skinprores.mov.zip
Simon Ubsdell
Re: FCPX and Resolve vectorscopes showing different images
on Dec 16, 2016 at 10:35:21 pm
In Resolve, if you select your clip and right click and go to Clip Attributes and set it to Video (or Auto) rather than Full, you should see the same result as you are seeing in FCP X.
Simon Ubsdell
tokyo productions
hawaiki
Maria Troitskaya
on Dec 16, 2016 at 11:32:37 pm
Unfortunately it doesn't work. Thank you.
Glenn Sakatch
on Dec 17, 2016 at 4:19:16 pm
This tells me FCPX is either interpreting the footage wrong, or doing something to it internally.
(This also tells me you might want to be careful if coloring in FCPX)
"How do I fix it?" Don't color in FCPX?
Glenn
Marc Wielage
on Dec 17, 2016 at 9:40:23 am
I would check normal SMPTE bars and see if they align in the calibration boxes.
I also don't recommend internal scopes for anything -- you'll get more accurate results (in general) with external scopes.
