create a version for all the clips of a timeline
COW Forums : DaVinci Resolve
Laura Fernandez
on Dec 1, 2016 at 10:03:23 am
Hello Everybody.
I was wondering if it is possible to do the next thing:
I have a 30 minutes long Timeline with a lot of clips. I have two grade versions and I would like to have the complete timeline with this both versions ready. So, is there a way to create a new version on all the clips at the same time?? Not talking about to create a grade, just the option of create an empty version on all the clips at the same time, so that I dont have to go one by one creating a new one.
Hector berrebi
Re: create a version for all the clips of a timeline
on Dec 1, 2016 at 11:40:32 am
hi
simplest way would be to create 2 versions at the timeline level (not clip) you can change that with drop menu at top of nodes window.
only thing is it seems there is a bug moving between versions using the Cmd-N shortcut and you'll have to do it manually right clicking on any clip (will change whole timeline). Checked on 12.5
other way would be by grouping, but I find it a bit more cumbersome.
