Offline Reference Clip looks MEDIA OFFLINE
COW Forums : DaVinci Resolve
Laura Fernandez
on Nov 23, 2016 at 10:36:37 am
Hello everybody:
I imported an XML, and a reference clip. I imported the reference clip as a reference clip in to the media pool and i linked the timeline to the reference. And once i go to edit and i activate offline it shows Media Oflline, but the reference clip still in place and everything is okei....any suggestion?
thanks
Joseph Owens
Re: Offline Reference Clip looks MEDIA OFFLINE
on Nov 23, 2016 at 5:20:48 pm
What is your media type that the reference clip is exported in?
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Laura Fernandez
on Nov 24, 2016 at 2:50:05 am
The reference clip is an H264 MP4
regards
Tim Donahue
on Nov 23, 2016 at 7:08:30 pm
I just had an issue with this recently. Check the start timecode of your offline reference clip against the start timecode of your timeline. My offline ref started at 00 hours, and the timeline was at 01, causing it to not line up correctly. You can alter the offline's timecode by moving the playhead in the viewer to frame 1, then going to clip properties by right clicking on the offline ref clip and choosing the timecode tab.
I hope this helps, it took having it happen twice this year for me to actually learn.
Laura Fernandez
on Nov 24, 2016 at 5:20:36 am
Fixed. Thank you both!!!!
Thomas Hannen
on Aug 17, 2017 at 4:52:49 pm
Just had the same problem - many thanks for the solution!
Jason Providence
on Aug 20, 2018 at 7:03:39 am
This really helped. Thank you so much for helping me maintain my sanity.
Declan Smith
on Aug 20, 2018 at 1:29:40 pm
Occasionally I've noticed a few oddities like this. I would suggest you could try deleting the render cache. Sometimes, I've updated clips externally (such as in After Effects), and they don't appear to update, even if the clip is removed and re-added, but closing Resolve and re-opening does then seem to bring the clip in as expected, so I suspect there could be a few levels of cache involved.
Declan Smith
http://www.madpanic.tv
Davinci Resolve / FCPX / Adobe CS6 / FCS3 / Zoom F8 / Roland R26 / Canon XLH1 / Canon 7D / Reason 10 / Cubase
"it's either binary or it's not"
