Flickering Issue in Color Mode & Export
COW Forums : DaVinci Resolve
anton purr
on Oct 20, 2016 at 4:17:57 pm
Hi Everyone,
I'm new to DaVinci Resolve Studio and working with the latest version. I'm have strange problems when using Color Mode - the image flickers randomly when I use playback or adjust settings - going from the applied grade back to the raw, Arri Mini MXF footage. I have the same problem when I export. However, when I'm using playback in Edit mode, the video is clear.
It seems like a video card issue but I'm not entirely sure. I'm working with the latest CUDA drivers. Please help! Many thanks.
iMac (Retina 5K Late 2015)
3.3 GHz Intel Core i5
32 GB 1887 MHz DDR3
AMD Radeon R9 M395X 4096 MB
Michael Gissing
Re: Flickering Issue in Color Mode & Export
on Oct 20, 2016 at 10:34:20 pm
CUDA is Nvidia. You have an AMD card. Make sure you have the correct driver for it and your OS.
anton purr
on Oct 20, 2016 at 10:42:20 pm
Thank you for pointing that out. I should have realized such an obvious thing. The problem is probably because I'm using an outdated driver that AMD or APPLE isn't updating to run these heavy programs.
