How to place a gradient INSIDE a tracked power window
COW Forums : DaVinci Resolve
Daniel Williams
on Aug 8, 2016 at 11:11:27 pm
title says it all!
Help!
Joseph Owens
Re: How to place a gradient INSIDE a tracked power window
on Aug 9, 2016 at 5:17:20 pm
If I am visualizing this correctly, you want to add another treatment over top of an existing one, but essentially a "grad" tracking with some object or horizon line or something.
I'd add a key output to the window node so the qualifier for your "master" secondary is available to a following correction node and use either the line/arrow or square generator to create the grad. You will probably need to copy the tracking info from the master qualifier and paste it into the grad or re-track it and hope its the same. The key will be acting as a Boolean operator.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
