Mac restarts when trying to render
COW Forums : DaVinci Resolve
Joe Loria
on Jul 20, 2016 at 10:15:56 pm
Hey everyone,
I found my flashed 09/10 Mac Pro is restarting whenever I try to render in DaVinci Resolve. Im only attempting to render out 2 min Blackmagic 2k raw clips to prores. Ive tried different output options, tried using gpu option in resolve, reset pram, and tried rendering from and too different hard drives both internal and external, but still the same problem. CPU temps seem to climb pretty quick during render but not enough time to overheat before restart happens (only gets up to about mid 60's celsius and it happens in a matter of seconds).
Setup:
2009 Mac pro (flashed to 2010)
96gb ram (owc)
dual de-lidded x5690's
Titan X (flashed by macvidcards)
Any ideas????
Matt
Joseph Owens
Re: Mac restarts when trying to render
on Jul 20, 2016 at 10:56:21 pm
have you tried throttling the render speed?
Do you have any particularly processor-intensive nodes in the grade? -- biggest cause of system overload is NR.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Nat Jencks
on Jul 28, 2016 at 3:59:10 am
Back when I was running a Mac Pro tower this happened to me a few times. Some research indicated it was the result of the power supply being overdrawn.
Not sure if thats the issue but if so you could look at 3rd party power supplies... good luck
-N
