DaVinci Resolve not showing full image
COW Forums : DaVinci Resolve
Anne Green
on Jul 9, 2016 at 5:59:17 am
I'm using Resolve for the first time on this computer and no matter what window I'm looking at, all I see of the image is the bottom right corner of the image in the top right corner of where the image should be. The rest of the space that the image should be taking up is black. While it doesn't do it to nodes it does do it to scopes as well. It's hard to explain but it should be clear what the problem is from the image.
Restarting the computer and using different files hasn't done anything
Sorry if this is an easy fix but I haven't been able to find anything searching for it
Joseph Owens
Re: DaVinci Resolve not showing full image
on Jul 9, 2016 at 3:03:57 pm
Either you have a software/installation/configuration conflict or a strange input scaling/centering transform.
Is the input image a differing resolution from the timeline/sequence setting; and how is your project configuration set to handle that disparity if it exists?
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
