resolve lut to avid
COW Forums : DaVinci Resolve
len hugh
resolve lut to avid
on Jun 21, 2016 at 8:06:24 am
We are cutting in avid and want to try some different looks however the colour corrector in Avid is limited.
I have been testing looks in resolve and then generating a 3d LUT which I can import into avid.
This way we can experiment in the cut with a colour lut effect and not have to retranscode media.
Its purely for offline edit work.
The only problem is that the black and white points are not matching.
I think its because the LUT coming from resolve is in a RGB space and my avid pictures are rec709. I have tested the path with some pluge and I think thats whats happening.
Is there a way to compensate? I am a bit of a newbie to resolve.
Thanks in advance.
Glenn Sakatch
Re: resolve lut to avid
on Jun 23, 2016 at 7:22:14 pm
you could switch your avid project over to rgb and see if that helps
Glenn
