Different sequence resoloutions on one project
COW Forums : DaVinci Resolve
Athanasios Kamaretsos
on Jan 28, 2016 at 2:11:12 pm
Is it possible to have different sequence resoloutions on one project in Resolve?
i.e A sequence at 4k another one at 1080p etc
Marc Wielage
Re: Different sequence resoloutions on one project
on Jan 29, 2016 at 2:33:47 am
Yes, but the trick is getting the aspect ratios to work for an entire project, which will probably require some compromises here and there.
on Jan 29, 2016 at 7:39:38 am
Thanks for your time in answering my question, but could you be more specific?
For what i have come to so far is that the sequence it self does not give you any editable preferences and the only way to change it is through the " Master project settings " in the case of witch, all sequences existing in the project are changing properties.
To be more specific i wish to know if there is a way to have i.e 3 sequences in the same project and let's say that
a) sequence 01 is 4k 25fps
b) sequence 02 is 1080p 24fps
c) sequence 03 is 720p 29.97fps
Marc Wielage
on Jan 30, 2016 at 2:13:28 am
No. Everything has to have the same rate as the project. This is pretty much etched in stone. My advice would be to make a decision as to how you need to deliver the project, and then alter the speeds for the clips shot at different rates and make them the same rate.
One of the basic issues of workflow is that you have to make a decision early on as to how to shoot the material in order to be compatible with your delivery requirements. If you don't do that, it can potentially be a trainwreck.
on Jan 30, 2016 at 5:15:32 am
Ok. So it works avidwise. The project rules everything.
Thanks again for your time!
