DaVinci 12 Viewer window is a thumbnail
COW Forums : DaVinci Resolve
Rebecca Murray
on Nov 30, 2015 at 2:44:24 am
I am new to Resolve. On the default settings I only see my clip in a tiny window in the viewer. I have tried dozens of things to fix this and just cannot figure it out! I definitely can't use resolve at this point because I can't see what I'm doing:(. I am sure this is something simple. Does anyone have an idea of what I need to do to get the clip to fill the entire viewer window instead of being constricted to a thumbnail view? Thank you!
Joseph Owens
Re: DaVinci 12 Viewer window is a thumbnail
on Dec 2, 2015 at 4:26:40 am
command-f
will fill your screen, but it is not meant to be your grade reference monitor. That sort of makes it a little easier to see window adjustments... also option-f will expand the viewer to fill the upper part of the screen and leave the adjustment controls on the bottom half. Again, not intended to be used as grade reference,as the display is subject to your Operating System ColorSync overrides.
Beware.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Rebecca Murray
on Dec 2, 2015 at 5:11:21 am
Many Thanks!!
Rebecca
