Multiple monitors in Davinci 12
COW Forums : DaVinci Resolve
Ali Quintana
on Sep 22, 2015 at 3:21:01 am
I would like to set up an extra monitor in davinci 12, but the option seems to have disspeared from where it was in Davinci 11.
Can any one tell me how I can set up an extra monitor.
I also want to set only the source viewer, so that I have a monitor on which I see the final result in big, the window inside Davinci is so small and every time need to click CTRL-F to see the full screen.
Any one has any info on this???
Marc Wielage
Re: Multiple monitors in Davinci 12
on Sep 23, 2015 at 2:30:15 am
Buy a BMD monitor card -- the MiniMonitor is affordable and will do the job -- and use a calibrated Rec709 monitor as your hero display. You can't do it properly within the operating system alone.
Read page 586 of the v12 manual: "Limitations When Grading With the Viewer on a Computer Display."
Ali Quintana
on Sep 24, 2015 at 1:10:00 pm
thank you, do I rally need that, I have a separate Mac Monitor, would love to use that.
I will read the manual as well thanks.
Rohit Gupta
on Sep 23, 2015 at 6:27:04 am
It's moved to the Workspace menu.
