Manually Setting White Balance with v12
COW Forums : DaVinci Resolve
Bill Ravens
on Aug 2, 2015 at 3:57:14 pm
With the revised CURVES window, it's very difficult to manually set the White Balance. V11 allowed zooming on the window, which also had a graticule. This current version is almost impossible.
Is there also some way to visualize the RGB curve values, and adjust them, for a white point or grey point?
Marc Wielage
Re: Manually Setting White Balance with v12
on Aug 11, 2015 at 1:59:11 am
I think you can still white balance with the primaries, but I have to admit, I miss the Big Curve Window mode from v11. I suspect a combination of desat curves and primaries will get you where you need to go.
