Mac Pro 2014 GPU
COW Forums : DaVinci Resolve
Búi Baldvinsson
Mac Pro 2014 GPU
on Aug 6, 2014 at 1:09:28 pm
OK.
I might be a nub her at the cow.
But I need a little helping hand.
What is the best way to speed up transcoding process.
Here is my setup.
MacPro 2014 12xCore 2ndGen
128GB Transcend DDR3 1866
Thunderbolt connected RAID speed up to 980Mbs
But when I am transcoding with Davinci 10, from for example Arri Raw to DnxHd. I only get 12fps max.
My pipeline should not be bottlenecked in any way.
I know ArriRaw is tough.
But there might a solution for thunderbolt GPU card.
Or any other settings
I have Sonnet chassis that I can use.
But my question is also is there anyone running a thunderbolt GPU with the MacPro ?
Or is there any other magic to set up this unit.
Any help will do..
ThanX
Bui Baldvinsson
DIT / Wrangler
Iceland.
MacPro 2014 2nd Gen.
12 Core
2x D700 GPU card
128GB RAM
Peter Chamberlain
Re: Mac Pro 2014 GPU
on Aug 7, 2014 at 1:36:45 am
You will not get a speed improvement using ThunderBolt and a GPU, even if you can get it to work. TB2 has a much lower bandwidth than the GPU buss connection to the MacPro motherboard and CPU.
Try using a different source disk than the target disk.. both Thunderbolt. Sometimes the speed tests are misleading when it comes to Read only or Write only compared to Read/Write.
You can test this by rendering to your SSD a small sample.
Rick Lang
on Aug 7, 2014 at 2:11:21 pm
What is the size of your internal flash? Did you go with the 1 TB option?
Rick Lang
iMac 27” 2.8GHz i7 16GB
Búi Baldvinsson
on Aug 7, 2014 at 2:12:35 pm
I actually just went for the 500gb drive...
But I am upgrading that one soon.
Bui Baldvinsson
DIT / Wrangler
Iceland.
12 Core
2x D700 GPU card
128GB RAM
Rick Lang
on Aug 7, 2014 at 3:56:30 pm
Búi, that may not help increase your Arri raw renders, but the experience of a few people here indicates that there is a general performance boost with the larger flash memory. I don't think it's been discussed much, but considering your configuration, you want to keep everything in balance. Peter's suggestion of separating your input from your (render) output may help significantly if you can keep the drives on a separate TB2 controller. As you know, you have three TB2 controllers that support the six TB2 ports plus the HDMI port. And I'm sure we all really need at least two Promise Pegasus2 R8s! Seriously though, just putting the rendered data on an external SSD may help and try to keep that on a separate TB2 controller.
Perhaps Peter Chamberlain knows if your next project will perform faster renders after you upgrade to Resolve 11.
I didn't realize there was a second generation of the Mac Pro yet, but I'll look into that. I assume it was minor.. If you have a moment, you can tell me what was improved. Improving the price, I'm thinking be nice.
Rick Lang
Marc Wielage
on Aug 11, 2014 at 4:07:48 am
Arri has an interesting white paper on how best to use ArriRaw in post:
http://www.arri.com/camera/alexa/workflow/working_with_arriraw/mastering/co...
I personally think LogC ProRes 444 looks perfectly fine, but if you have the (massive) horsepower required, you could theoretically use the original ArriRaws. I think for 90% of most projects intended for indie release and TV, the ProRes is all you need. I don't think an off-shelf Mac will be enough for ArriRaw; I think you'd need a heavy-duty 8-proc Linux system with very, very fast drives to handle this.
John Sellars
on Aug 12, 2014 at 4:50:12 pm
Can you tell us the exact size and aspect ratio of your footage? I would like to test this on my system with the footage from here:
http://www.arri.com/camera/alexa/learn/alexa_sample_footage/
I assume this is transcode only… no nodes right?
2012 12 core 2.4GHz
GTX 780 6GB
24GB RAM
internal RAID 0 480MB/s
John Sellars
on Aug 15, 2014 at 5:17:30 am
I get 32 FPS rendering 2880x1620 to DNxHD 185, and 28 FPS for 2880x2160. That is for reading from, and writing to my internal RAID.
